- 5 Aug 2003
- Essex
I've just bought a new car and the insurance company (Aviva) mandated that I get a tracker fitted before they'll cover it, so I asked if there was a particular model or brand that they recommend and they said just get a Thatcham approved one.
I looked around on the Internet and found the Tracker Retrieve product, had a read up on it and it sounded like it fit the bill as it is Thatcham Cat 6 approved.
I had the tracker fitted and rang up Aviva to switch the cars over and inform them I'd had the tracker fitted, they then asked me what model and guess what, they said it isn't one that they approve!
Thankfully they listened back to my previous call and found that I had been ill-advised and on this occasion they said they would cover me.
So in short, make sure if you have to get a tracker fitted that you check with the insurance company first as even if you get a Thatcham approved one they may not cover it!
