Wordpress Design
29 Dec 2004
Chatham, Kent
http://92.40.47.235/irc/
Code:
<body>
<div id="wrapper2">
	<div id="header">
         	<h1><a href="<?php bloginfo('url'); ?>"><?php bloginfo('name'); ?></a><form method="get" id="searchform" action="<?php echo $_SERVER['PHP_SELF']; ?>"><input type="text" value="<?php echo wp_specialchars($s, 1); ?>" name="s" id="s" /><input type="submit" id="sidebarsubmit" value="Search" /></form></h1></div>
I want the search bar on the right of that section.
How do i go about doing this?
Thanks,
Andy
Can't see the page, but what I did on my website was wrap a div around the search function and floated it to the right.
Code:
HTML
<div id="search">
<form method="get" id="searchform" name="searchform"><input type="text" value="" name="s" id="s" /> <input type="submit" id="searchsubmit" value="Search" class="btn"/></form>
</div>
Code:
CSS
#search {
   float: right;
well you *** try adding
#s
float:right;
and then the search box should float right, but until you load the page so people can view it, its hard to help :-S
