Wordpress help
10 Sep 2008
Grendon
Hello again :p
Still getting to grips with wordpress and abit stuck atm.
I am using a downloaded theme on a wordpress site im sorting for a family member of the wife.
site is http://hanamurray.co.uk/
Now the flickr "widget" that came with the theme seemed like a great idea (But she decided she does not want to use flickr) thats fine as i found a decent gallery script and using that instead, but on the homepage it still has the flickr photos.
Is there a way i can change the flickr stuff so that each time you go to the homepage in the same place it still displays 10 photos, but they are random ones from the folder with all the uploaded photos for the gallery. And then when you click them it takes you to that photo in the gallery?
Not sure if ive been looking at the pc for too long today but it's confused the hell out of me
*edit*
The theme is Irresistible if anyone would care to take a look?
One more thing while im asking.
The text on the right (above the photos) what would be the best way to go about removing that and having the photos up there (withought it lowering the rest of the stuff below it)
