Intel Core i7-3930K 3.20GHz
RayStorm Intel CPU Waterblock
OcUK Tech Lab - V12 Watercooled
Corsair 800D / not entirely sure of the 900D but it's a possibility.
XSPC EX140 Single Fan Radiator
Enermax T.B.Silence Manual UCTB14A 140mm Fan
Asus Rampage IV Extreme Intel X79 (Socket 2011)
OcUK Tech Lab H2O Custom HD 7970 3072MB GDDR5
XSPC Razor 7970 GPU Waterblock (Raystorm Style)
OCZ Vertex 4 256GB 2.5" SATA 6Gb/s SSD
Corsair Dominator PLATINUM 16GB (4x4GB) DDR3 PC3-15000C9 1866MHz
Seasonic 860w '80 Plus Platinum' Modular Power Supply
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache
Mayhems Ice Dragon Nano Fluid 1L
Mayhems Dye Ocean Blue 15ml
& a couple other comsmetic things...
In a couple months time I'll be ordering the above parts, I was hoping to get peoples opinions, suggestions etc
On the 360 Rad I was considering the Enermax T.B.Silence 120mm fans over the Scythe Gentle Typhoon 120mm 1850 RPM that come in the V12 Pack, they seem to give better airflow for half the Db. Static pressure on the Enermax is (mm-H2O): 0.722 - 1.676 but I have no idea if this is good/bad or terrible lol
I've saved for a hell of a long time to afford this and it's going to have to last a fairly long time as well!
Basically I was after a good looking, quiet system for gaming and a bit of overclocking but to also be a work horse handling large image files and video rendering as I'm a Photographer.
The loop I was planning was Res-360Rad-CPU-140Rad-GPU-Res
With this setup do you think I could have a good stable oc of 4.5ghz?
Any help would be hugely appreciated!
