Work related (IT) issue
6 May 2009
I have had my permission to the servers revoked as of today. My boss said that ive been trying to grant myself higher persmission to the AD structure and consequently all permissions throughout the AD tree have been reset.
He said that my username appears in every single OU, Group, User file, with the same specific Group Policy permissions in everything. When I forced the propagation down the tree to include my credentials, I reset all the permissions on everything else. He has been spending days resetting individial enteries to fix errors.
I do not have domain admin access rights, how could I have done this? I used a temp account a couple of times to edit group policies but thats about it. I have never even been on to security permission on OUs
Thanks
If you don't know if it was possible, then you shouldn't be messing with permissions and I agree with the decision to revoke your rights based on what you have said.
There are 2 ways to have enough rights to be able to change Security in AD, either your account has been delegated rights, or your account is a member of Domain Admins groups. Either way if YOU would have caused this you would have known as when you propagate down security rights it comes up with a warning!! and even then you would have not only had to of clicked the warning off, you would have been given a choice between cancel, copy and remove.
Depends really, what security level does the accounts you are using have?
It's highly possible. But sounds more like you've been setup. It can be checked though if Auditing/Logging is enabled i believe.
Sounds like a setup, If he's unable to fix something like that fairly quickly (restore anyone?!) then he shouldn't be in mucking about in AD either.
Ultimately if you were granted permissions and given no training the buck stops with your boss, however I find it highly unlikely that you'd be able to mess up an entire AD structure so easily and not realise you'd done it. It does give warnings and I'm guessing from his claims of having spent days fixing it that it's possibly messed up mappings, scripts etc. But then again these are easy to fix even without a full restore of AD.
Just ask for training or have nothing to do with it, I wouldn't be owning up to anything though, not without proof that I'd done it. AD can become corrupt just like everything else, did he even consider a restore?
I had admin rights but not domain admin rights. Would I have been able to delegate my own rights somehow? Ill ask him about the restore of AD. I did think about a restore instead of sorting all the permissions again
I have never seen any warnings or boxes in AD in the past few weeks
So to be unsure as to whether you've done this you've obviously tried but thought that you wouldn't be successful, you have been and now you're papping yourself.
Thanks
could be some really sloppy administration. we had a similar issue here caused by some people leaving the 'inherit permissions from parent' box ticked when they created shares. this would, in effect, cause any permissions you set to be pulled down the tree. you would not get a warning if you changed the permissions on the parent subsequent to this being set. i think.
that said, if all you did was add yourself, then the rest of the permissions would have been unaffected.
*goes off to poke ad*
TG
no, if i tried something like this (by mistake) and then seen a load of warnings then i would have stopped or presses cancel.
However if i accidentally ticket a box and pressed ok and no warning message came up then its a possibility. I wouldnt have thought it could be done with domain admin access though
There is next to no chance you could have done this without noticing, I still don't believe that you can be considering that you might have accidentally done this, rather than having done it not expecting it to work. You've done something, not accidentally but just seeing what you could do rather than maliciously, and now you've been caught and you're trying to find a way to cover your back.
I had access to a domain admin account, there are far worse things i could have done, but never would have.
So, could I have added myself to permissions of an entire OU, even without domain admin access?
but you've just said that you did it with a domain admin account, you could not give yourself rights higher than your current permission level, it is obvious to your boss that you've used a domain admin account.
The account with domain admin is a temp account. If i did it through that one, my name wouldnt appear in groups etc. It would be the temp account. So couldnt have been that one
