Just done a bit more work.
1 Moved the Rad to the roof
2 moved the HDD
3 Changed the position of the pump and res.
Ive included a pic of the case when i 1st recieved it.
Cooling wise its got 2 x 120mm lower front, 2 x 120mm upper front and rear (both sucking in) and the 2 x 120mm on the rad blowing out.
Just needs a little tidying and something more permanent for the HDD to sit on.
Not bad for a case that cost £40 inc Del
2 moved the HDD
