Hi all
Wanted to pick your brains on the best kit to go with a new 10Gbps sequential FTTP install. So far, thought process is:
1) Buy a 10Gbps switch - seems plenty about, any suggestions?
2) Buy a workstation/server with a 10Gbps NIC in and some NVME drives to be able to cope with the throughout
3) Utilise my current WiFi6 mesh kit (ASUS) to feed around the house and existing gigabit switches for kit that doesn’t need 10Gbps (most!)
This is where I’m at - still can’t decide the best way to proceed!
Probably going to run something like proxymox on the machine, so I can virtualise different things (Plex, cctv, firewall, vpn etc..) so I’m trying to decide the best sort of machine would be best here.
1) Second hand workhorse, with dual Xeon and loads of ram:
HP Z820 WORKSTATION (24Cores/48Threads)
MAIN SPECIFICATION:
Processors: Dual, 2 x Intel Xeon E5-2697V2 (2.70/3.50GHz, 12C/24T)
Memory: 256GB DDR3 ECC 1866MHz
Graphics: NVidia Quadro K5200 (8GB GDDR5) GPU. (Probably sell this and buy a P2000 for better Plex transcodes)
Storage: 256GB SSD New (OS)
3 x Caddy Trays included for additional HDDs
Optical drive: DVDRW+/-
Power Supply: 1125W 90% High Efficient PSU
Integrated: Gigabit Ethernet
Integrated: HD Audio
Ports: 4 x USB 3.0, 5 x USB 2.0
OS: Windows 10 Pro
(£1600 for the above)
2) Newer machine - any suggestions based on the above (rough) use case?
MAIN SPECIFICATION:
OS: Windows 10 Pro
