Working out ASHP efficiency at a certain temperature.
Sgarrista
System Admin
9 Aug 2013
Bromsgrove
Hopefully some of you big brains here have some experience of this.
I have an ASHP heating a pond.
I know what a number of values are, but wondering if from those we can work out (even if approximate) some specific values.
What I have:
Air Temp: 26 c
Water Temp: 26 c
Power in: 0.73kw
Power out: 4.25kw
Cop: 11.60
Air Temp: 15 c
Water Temp: 26 c
Power in: 0.75kw
Power out: 3.15kw
Cop: 6.75
Air Temp: -15 c
Water Temp: 26 c
Power in: 0.71kw
Power out: 1.40kw
Cop: 3.22
From that is it possible to work out or made a general indication of the following:
Air Temp: 0 c
Water Temp: 18 c
Power in: 0.75kw
Power out: ? kw
Cop: ?
Why's the output of the heat pump greater at an air temp of 26c then it is at an air temp of -15c, to get the same water temp? :confused:
Youre over thinking it, latent heat is easier to absorb at higher temps.
Think of it like taking some water at -15°c (be an ice block) and taking it up to 50°c would take way more energy than 26°c > 50°c
You’re taking that similar heat difference from the air and putting it into the heat exchanger to heat the water up so the output is much higher.
Why's the output of the heat pump greater at an air temp of 26c than it is at an air temp of -15c, to get the same water temp? :confused:
It’s looking at power, rather than overall energy for the day. The unit probably operates at a set power but may run for far less time when at higher outdoor temps (when it can extract more power from the surrounding air than at lower air temps).
