Working out number combinations?
Caporegime
12 Mar 2004
England
I've completley forgotten how to do it. If you have a set of numbers with a certain range how do you work out how many combinations there are?
Ummm, like for instance, you have a padlock with a 3 digit code?
imagine all the numbers as 9, then add 1 ?
eg, in my padlock idea the highest you could go would be 999 - then add 1 because 000 could be considered a combination?
*disclaimer*
I didn't listen in GCSE maths, and if there is some mathmatical formula that your after, ignore this post :)
My brain shuts down when trying to do combination work :/
I say a 3-roller 0-9 combination lock has 1,000 combinations:
000
001
002
003
004
097
098
099
100
101
996
997
998
999
Non?
*n
Surely it's a simple case of, four digits, 0-9 therefore possible combo is 10x10x10x10 therefore 10'000 combinations?
edit - penski is on my wavelength, but with a 3 digit example.
indeed, all about powers....
Well, that's different, because with the lottery, when one number has been chosen, it is then out of the equation. Say with a padlock for example, each number always exists.
ie. can be 0-9 x 0-9 x 0-9 x 0-9 combination.
With the lottery, there are, for the first ball, 49 possibilites, the second on 48, the third only 47 and so on.
oh yea good point :)
In which case i believe your theory of Powers is correct - i shoulda read the post correctly
Its the same with PIN's 10,000 combinations :)
Energize said:
I didn't think it was as simple as powers otherwise the chance in winning the lottery would be 13,841,287,201:1
That's beacuse the same number can only be picked twice. If there were 49 balls for each number drawn, then the odds of getting all 6 balls would be 49^6.
The initial post is ambigious....
Are you talking combinations as defined in mathematics (essentially how many ways can I choose k items out of n?) or are you talking combinations as in, say, a combination lock (how many k digit combinations are there where each digit has n possible values?). They are distinct questions with very different answers.
