Hi 8pack, just built a Asus x79 Deluxe mobo+4820k combo+TeamGroup 2133 ram and l must say its a very good combination, stable overclock at 4.6ghz 1.344v>CPU-Z ram at 2133mhz for 24/7 running with very good temps Custom H2o Cooled.
Your help needed to see if l'm on the right track, to find the offset voltage needed see example below -
4820k 3.9ghz at stock at 100% load say l need 1.232v[CPU-Z], them OC'd at 4.6ghz voltage need is 1.344v[CPU-Z].
Do l just take away stock voltage at 100% load>1.232v from OC'd voltage at 100% load>1.344v=offset voltage +/-.
1.344v - 1.232v=0.112v is your offset voltage.
So in this case offset would be +0.112v, Bios offset would be nearest setting.
As it worked out my offset voltage is +0.085v giving me 1.344v[CPU-Z] seems to be ok and stable, temps good.
Thanks,
Oldphart.
Thanks,
Oldphart.
