- 19 Dec 2022
- UK
Hi all. Completely lost about the cause of my PC not booting. Built PC approx 3 years ago, been used every day since, working fine. On restarting it a couple of days ago it no longer POSTs.
Specs are:
- Asus ROG Strix B450-F Gaming
- AMD Ryzen 5 3600
- Corsair DDR4 Vengeance LPX Black 32GB (2x16GB) (3200)
- ASUS ROG Strix OC Gaming RX5700 8GB
- Seasonic 650W Prime Ultra Platinum
- Samsung 970 Evo Plus 1TB
On boot up fans start up but I get no display and no POST. Mobo debug LEDs cycle and then stops on the white (VGA) led.
Things I've tried with no success:
- Reseated all components
- Reset CMOS (by both removing CMOS battery and using reset jumper)
- Moved GFX card to other PCI slot and then back again
- Substituted in alternative PSU from old PC
- Substituted in alternative GFX card from old PC
- Tried both sticks of RAM independently
- Tried alternative monitor
I suspected perhaps the motherboard was faulty so bought a used MSI Tomahawk X570S Torpedo Max WiFi. Using this I also get fan start up but not POST. The Mobo debug LED on this one gives the red (CPU) LED.
Any ideas?
2 dead motherboards? (unlikely?)
Dead CPU? (pins all look OK, and working fine before restart)
Many thanks.
Specs are:
- AMD Ryzen 5 3600
Any ideas?
Many thanks.
