Working with Plexi / Making a Plexi Case for a cpu.
Man of Honour
30 Oct 2003
Essex
Long story short i'm doing up my office/man cave and want to display some new and old hardware, specifically CPU's and im looking for some sort of stand or case that either I can make or buy to pop them into or on top of before displaying.
For example I have 3 spare AMD chips, 1x Ryzen, 1x TR and 1x EPYC (seen in this post: https://forums.overclockers.co.uk/posts/33167742/) that I want to display next to each other. Somebody recommended a frame and framing them but I dunno I'm thinking cool plexi stand that perhaps I can light the plexi and make it look cool. Anyone work with plexi or seen something similar I can buy?
I’d just google plexi display case.
I imagine it’d be easy for it to look rubbish making your own unless you’re skilled.
Yea this is my problem. I'll try my hand at pretty much anything but really what I'm looking for is little pre made stands that are about cpu sized, I'm not really sure about the boxes or case. I'm thinking more a little stand type thing so I can just sit them on a shelf. I'm not going mad numbers wise I have a couple of intel classified cpu's (engineering samples) the recent ryzen lineup and that's about it perhaps 6 or so cpu's all pretty modern. Just need some sort of little cpu stands.
