- 15 Dec 2011
Hello,
I have started to shoot in JPEG+RAW (Canon 7D).
Can anyone offer some advice/words of wisdom how you manage/organise your files when you get home.
Currently I load all the pics I have taken into a folder then use "Digital Photo Professional" to view them one by one and check if they are Ok.
I look at the RAW Photo and if it isn't "right" I select the RAW+JPEG version and delete.
Is there a way to automatically delete the corresponding RAW/JPEG if I delete the other? Each file name is the same eg IMG_4575.JPG + IMG_4575.CR2.
Appreciate anyone's 10p worth!
Thanks
Thanks
