WORKSTATION BUNDLE RANGE EXPANDED!
11 Dec 2005
Cheshire
We have expanded the range of our Workstation PRO edition bundles. Now with the all mighty Intel X79 chipset and up to 32GB of RAM available!
Workstation PRO Z68 Intel Core i7 2600K 3.40GHz @ 4.50GHz Overclocked Bundle - 16GB @ £549.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.50GHz overclock has the processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
Why You Should Buy This Bundle?
- A solid, optimised 4.50GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 16GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- CPU: Intel Core i7 2600K 3.40GHz @ 4.50GHz Sandybridge CPU
- Motherboard: Asus P8Z68-V GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Cooler Master Hyper 212 EVO CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £549.98 inc VAT.
ORDER NOW
Workstation PRO P67 Intel Core i7 2700K 3.50GHz Bundle - 16GB @ £699.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Intel Core i7 2700K processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
* Windows 7 Professional 64 Bit is recommended as minimum to fully utilise this bundle's potential
- A solid, optimised 3.50GHz core speed with 4 core performance provides outstanding processing power
- CPU: Intel Core i7 2700K 3.40GHz @ 4.50GHz Sandybridge CPU
- Motherboard: Asus P8P67 WS Intel Z68 (Socket 1155) DDR3 Motherboard
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Only £699.98 inc VAT.
ORDER NOW
Workstation PRO X79 Intel Core i7 3930K 3.20GHz Bundle - 16GB @ £949.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The intel Core i7 3930K has the processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 16GB of RAM at your disposal you can run even the most demanding of programs
- A solid, optimised 3.20GHz core speed with 6 core performance provides outstanding processing power
- Prebuilt and configured. Just "plug and play"
- 16GB of Quad Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i7 3930K 3.20GHz Sandybridge-E CPU
- Motherboard: Asus P9X79 PRO Intel X79 (Socket 2011) DDR3 Motherboard
- RAM: G.Skill RipJawZ 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel
- Cooler: Phanteks PH-TC14PE CPU Cooler - Silver
Service Package
Only £949.98 inc VAT.
ORDER NOW
Workstation PRO X79 Intel Core i7 3930K 3.20GHz Bundle - 32GB @ £1,199.98 inc VAT
Designed by experts the "Workstation PRO Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The intel Core i7 3930K has the processing power and speed unseen at this price point ever before. The "Workstation PRO Bundle" will accelerate your computer experience into the next level. Designed for intense workstation applications, with a total 32GB of RAM at your disposal you can run even the most demanding of programs
- 32GB of Quad Channel DDR3 memory delivers unsurpassed bandwidth
- Motherboard: Asus P9X79 WS Intel X79 (Socket 2011) DDR3 Motherboard
- RAM: G.Skill RipJawZ 32GB (8x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel
Service Package
Only £1,199.98 inc VAT.
ORDER NOW
