****WORLD FIRST: GIGABYTE GTX 780 WindForce 3x OC AVAILABLE FOR PRE-ORDER AT OcUK!!***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've secured one of the first batches of Gigabytes amazing Windforce 3x OC GTX 780 and are the first website in the world to make this product available for order. We expect the first batch to arrive mid-end June as long as Gigabyte have no production issues:-
Gigabyte GeForce GTX 780 WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) @ £629.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- WINDFORCE 3X 450W Cooling system
- Black PCB
- GPU: GeForce GTX 780
- Core Base Clock: 954 MHz
- Core Boost Clock: 1006 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £629.99 inc VAT.
ORDER NOW
