World In Conflict Problems?
Running a GTS 320 OC 630/950
Xeon Quad @ 3Ghz 4 Gig Ram, Vista DX9
1920x1200
Medium Texture and 4X Ani, No AA everything else on High or Very High ( Maxed )
Average 29
Min 8
Max 76
Only just finished playing the tutorial but very smooth. If your running in Vista try turning off Dx10.
What are you getting with the built in benchmark?
mines about the same with 4xaa and same other settings in dx10 i think as i havnt disabled it in intense battle it can get a little stretched but on the whole runs ok with about the same benchy results as above
I run mine is 1680*1050, All max settings, everything turned on in DX10, 8AA and it's perfectly playable, I don't notice the frame rate drop when something big happens, if does it's only for a second or 2.
