WORLDS FIRST 12x BLU RAY WRITER DRIVES FROM PIONEER PRE-ORDER NOW
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Pioneer BDR-S05 12x Blu-Ray Writer / 16x DVD±RW Drive - Black (Retail) @ £188.99 inc VAT
Pioneer introduces the world's first 12x BD-R/BD-R DL optical drive. The BDR-205 Internal Blu-Ray Disc/DVD/CD Writer is the lastest generation in technology. This revolutionary product will write up to 12x on BD-R (25Gbytes) and BD-R DL (50Gbytes) media give you more time to play.
Write Speed
12x BD-RE and BD-RE DL/BD-R
16x DVD-R / +R
6x DVD-RW
8x DVD+RW
8x DVD-R DL / +R DL /BD-R/BD-R DL
40x CD-R
24x CD-RW
Read Speed
8x BD-ROM/BD-ROM DL / R / RE
16x DVD-ROM and DVD-R / +R/DVD-R
12x DVD-ROM DL , DVD -RW / +RW and DVD-R DL / +R DL
40x CD-ROM
40x CD-R
24x CD-RW
Only £188.99 inc VAT.
PRE-ORDER NOW
Pioneer BDR-205 12x Blu-Ray Writer / 16x DVD±RW Drive - Black (OEM) @ £169.99 inc VAT
Pioneer introduces the world's first 12x BD-R/BD-R DL optical drive. The BDR-205 Internal Blu-Ray Disc/DVD/CD Writer is the lastest generation in technology. This revolutionary product will write up to 12x on BD-R (25Gbytes) and BD-R DL (50Gbytes) media giving you more time to play.
Write Speed
16x DVD-R / +R
6x DVD-RW
8x DVD+RW
40x CD-R
24x CD-RW
Read Speed
40x CD-ROM
40x CD-R
24x CD-RW
Only £169.99 inc VAT.
PRE-ORDER NOW
The last tray drive I bought came with beige, silver and black faceplates - I don't know whether this is still common practice though.
Yeah, i may be wrong but i believe some retail optical drives come with the interchangable faceplates?
Very cheap for a quick blu ray writer :), shame the media for them are still sky high.
I think there's a bit of confusion with the model numbers? The title for the first says -S05, which matches the image. But the text for both says -205. Are they actually the same drive, just retail vs. OEM? If so, which model number is correct?
So, I should buy a new case just because you won't stock silver drives?
:rolleyes:
you could spray paint it.
Seriously 95% of cases are black nowadays, so there's no point them releasing a new SKU as that costs them money.
Its a nice drive, £170 is a bit steep but could have been a lot worse, nice to see ocuk being the first on the pre-order for this. America has had this drive for about 3 months now, pioneer has been so slow bringing it to the uk :(
Btw, a lot of 6x discs will write at 10x/12x incase people were wondering where 12x discs are.
4x BD-R 25GB are pretty cheap now, some of the cheaper brands do 10pcs for £12-14 so £1.20 per disc. 50GB discs are stupidly expensive.
