Worms Armageddon
Caporegime
18 Oct 2002
Lake District
I'm trying to get this to work on my eee, and as it lacks a CD drive I'm having to use a nocd, problem i'm having is that it's unable to find the mission files even if I copy them into the WA directory :(
Seems the file pointer is still looking for files on the media it was installed from :(
you could try something called WormKit, which has a module called FileOverride, although I'm not sure about compatibility - I think it needs a patched W:A, which may or may not cause the no-cd not to work.
patch is at http://wa.team17.com/main.html?page=supp&area=upda
Basically you run wormkit with fileoverride and it looks for the missions in the w:a folder before looking on the cd
edit: just to make sure, this app was made by one of the developers of the official beta updates so it's all legit
