With my spec below i am only running three fans in my Coolermaster CM690 Adv case, one 120mm for the cooler rad, one bigger one on the front (intake and not sure on size) and one 120mm on the top (exhaust).
Is this enough, as when playing games it seems to be displacing a lot of heat
Incidentally, where can i download some temp monitoring software and what do you recommend? ATM i can only monitor GPU which is aroung 60-70 on load but im more worried about CPU and RAM etc.
