Hi all,
I'm just busy overclocking my new CPU (s939 x2 3800+). At the moment, it's going quite well. I've hit 2.6Ghz with no voltage increase at all. However, when running Orthos testing the stability, with MBM5 monitoring temps and voltages, I saw the PWMIC go over 70ºC!! The alarm started sounding obviously from MBM5.
Is this a problem at this temp?
I don't ever remember having this problem with my old CPU/Overclock and that was running at 2.8Ghz with massive voltage increases across the board.
Why is it running so hot under load now??? Does dual-core put more "strain" on the system? Chipset temps are ok as well as the CPU temps. I'm a bit worried about this.
I have also checked in the BIOS incase one of the voltage options were set to AUTO and therefore increasing automatically, but none are.
Thanks for any help!
