Just built a new rig i7 930 asus P6X58D-e motherboard with prolimatech megahalems cooler and 2x120mm fans push pull...yes they are in correct direction of airflow too.
idle temps are between 31 and 40 degress..problem is wen i do occt test or burn in test or any cpu test the temp goes immediatley, as in 1 second, up to 53 or so degrees then goes up to a max of 66-68 degrees over the space of 3-4 mins on all cores and stays there forever
cpu hasnt been overclocked at all except from asus turbo mode in ai suite takes it to 2.945 or something...i thought i may have poorly seated cooler or put too much paste on cpu but cooler itself is getting warm so paste is transmitting heat ok...
temps seem way too hot for me..i gotta be missing something, what have i done wrong??
using occt for monitoring temps and testing ,also everest and speedfan all report same temps, case is well ventilated however with front cover off it is sitting now at 60-63 degrees on all 4 cores
oh and after turning occt off it immediatly return to 40 degrees on all cores
