Hello,
I'm running MemTest86+ v1.70 and within a few minutes it started pumping out errors.
I don't understand the results but seen as the count is constantly increasing and its in red I'm guessing it's not good. The test is still going. I just wanted to get some inital ideas because errors so early couldn't be a good sign. I should add, the system has been runnign Windows XP SP2 perfectly fine the past few months however recently I've been seeing Firefox 3 crash more and more. I put it down to being a beta.
The RAM in question is Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663), bought on the 13th May 07. The reason I'm testing it now is that Vista had some errors during install and several people have recommended testing the RAM.
What do the results mean? What actions should I take? Is this a permant problem or would something like resetting the BIOS and rechecking the BIOS settings work?
Edit: After posting this I went back to see a screen full of red. On test 5 it had added 9 more lines but these contain different letters for the Good/Bad with the failing address 992.1MB.
It's been going 15 mins - error count 343.
Thanks.
Tst: 2
Pass: 0
Failing Address: 003d082cb0 - 976.1MB
Good: 00000000
Bad: 10000000
Err-Bits: 10000000
Count: 115 at 24% of pass
Chan:
Thanks.
you will need the full 2.2V,maybe a little more 2.3V
