I recently got the Q6600 and the temps are a bit worrying. Running on an MSI Neo-2 FR and using Artic Cooling Freezer 7 Pro. I am running at stock at the moment since i am waiting for my new PSU to arrive and possible solve the temp porblem i am now facing.
My case is a Thermaltake Tsunami and it should provide sufficient airflow. Reading the temps from bios and now using CPUID Hardware monitor the cores run as follow CPU0: 47C / CPU1: 47C / CPU2: 40C / CPU3: 37C in idle which seems a tad high since my old AMD X2 used to be much cooler overclocked than the Q6600 in idle.
Could this be a bios issue not reading the bios correctly or a cooler issue since i don't put much trust in Intels method of securing the cooler. I didn't use AS5 since i heard that the cooler i bought uses the MX-2 compound which is equiveland or better than AS5.
Any ideas guys? Thanks in advance.
