I have all the luck![]()
Just try and see. You might be pleasantly surprised.
And still bears no relationship to how it clocks or even what voltage you need to run it at stock.
Tbh, the only vids which seemed to matter were the VID's on q6600.
My q9650 has a VID of 1.25v yet will run overclocked at 4Ghz, 8 hours prime stable at only 1.23v, less than the supposed stock voltage required to run it at 3Ghz.
Yeah but I've yet to see a low-VID chip that doesn't clock well. In my experience high VID chips don't necessarily clock poorly, but low VID chips pretty much always clock very well.
with 1.43V set in bios
1.38 actual - max overclock so far is 3.6 stable .... not that great really !!
and a Q9650 at its stock clock - I'd say a VID of 1.25 is pretty good
I agree with the above btw I'm sure there is still some correlation ..
yup and to counter that - my 1.325VID Q6600 (I get all the luck) needed 1.5375V (in bios) 1.5 actual to run at 3.5![]()
