Worth £200?
12 Dec 2005
I am considering buying the following PC from a relative for £200, however I'm wondering if I'm getting a fair deal? The only issue is, it has no graphics card.
Specs as follows -
AMD Phenom X4 955 3.20Ghz,
4GB DDR2,
250GB HDD,
400W Corsair PSU,
Zalman Z7 Case.
Motherboard - Gigabyte GA-MA790X-UD3P
Cheers
I would say so:
AMD Phenom X4 955 3.20Ghz ~£80-90
4GB DDR2 - depends on brand but ~£35-£45
250GB HDD, ~£20-£25
400W Corsair PSU ~£30
Zalman Z7 Case ~£35
Motherboard - Gigabyte GA-MA790X-UD3P ~£40-£50
aprox prices for used components.
£200 is about right. Chuck a decent gcard in it, say a 460 and it's a decent gamer too. A Corsair 400w should handle a 460. Or if you want to play safe a 5770.
Thanks guys. Just wanted to make sure I wasn't paying over the odds!
Hopefully it would be a decent gamer with a good GFX card. :)
