worth an upgrade ?
8 Dec 2012
Intel Core i5 3570K 3.40GHz
16.0GB Dual-Channel DDR3 668MHz
ASUS MAXIMUS V GENE LGA1155
2047MB NVIDIA GeForce GTX 660 Ti
111GB Samsung SSD 840 Series ATA Device (SSD)
1397GB Seagate ST1500DL003-9VT16L ATA Device (SATA)
PIONEER BD-RW BDR-207M ATA Device
Realtek High Definition Audio
PSU http://www.xigmatek.com/product.php?productid=166
Case http://www.xigmatek.com/product.php?productid=154
getting the asus gtx 970 on wednesday just wanted to know will be a worthy upgrade from what i have now
if you sorted GPU, then probably not.
maybe CPU cooler and bigger SSD.
what monitor are you using? is 3570K overclocked?
what's the budget?
If you fancy over clocking you could put some money into a new cooler, the Themis is a good shout for £20 though for £50 you can get a TD03 CLC unit.
The 970 will 'boss' 1080p and even 1440p, so you can easily upgrade your monitor to 1440p or 144hz and not affect performance.
The upgrade from a 660ti to the 970 will be a big leap.
