Worth buying ?
I personally went for the Hanns G because its resolution is 1920 x 1200. It also seemed to get better reviews but then the Iiyama also seems like a good budget buy.
much of a difference between 1920 x1200 and the norm 1920 x 1080
well instead of slightly better resolution...as in visually is it much better
