Worth Changing - DS4 to 680i
If you will be wanting to run SLI, then yes. If not theres probably not much point. The 650i is probably the better choice value wise anyway.
Unless the 680i was extremely cheap then I wouldn't bother as you'll get no more of an overclock and if you're looking for enhanced graphics performance, the DS4 supports Crossfire 1 anyway.
DS4+8800GTS will compete with most things, surely?
