Worth changing fans?
21 Nov 2008
West Midlands
I currently have 3 Lian Li stock fans (the ones you get when you buy a Lian case), is it worth upgrading these to something like Sharkoon Silent Eagle 2000 or the Noctua NF-S12 1200RPM?
Many thanks!
Why do you think so? Is it the noise? You could keep the original fans and fit a fan controler and adjust the speed (and thus noise) to suit.
I got a fan controller but i was just pondering whether changing fans would make a difference on cooling my hardware :confused:
If fans are same as ones which come with A71 they should be quite decent for stock fans when undervolted.
But basing to simple testing I did at least Scythe Slipstream gives better airflow with same noise.
