I currently have the Coolermaster HAF 920 case, and I was planning on changing it to get an Obsidian 800D.
Is this a worthy change, like are there any major differences apart from the size?
cheeers,
There's no such thing as a HAF 920 Do you mean the 912, 922, or the 932?
Air cooling-wise, the HAF series do a better job, but for water cooling the 800D is perfect to work with.
ahh you can tell i'm still new with PC's then ;D umm it is this one http://www.kcusten.com/cm_haf932-3.jpg
ahh so your advise would be to stick with the HAF until I decide to input watercooling in and then go for the 800D?
Since it's the 932 I would stick with it, even for water cooling. It's a great case, since you can add a triple radiator on the top. I have the 932 myself
