my conclusions from de-lidding
If it is purely for a temperature drop then fine but if its to gain more Hz then you need to know how your chip scales, under water this is quite easy as your not so temp limited.
The point at where you need big voltage increases to gain that extra multi is the place to stop and tune. No delidding or lapping is gonna make your chip use less voltage than it requires.
To my disappointment I have found this to be true... thought I could push for 4.6Ghz or more on mine after delidding but no... temps are down, which is nice, but can't get anymore Hz out of the chip...
As for the risk aspect... of course there is some risk but I'm generally clumsy and very impatient yet I managed it fine (razor method).
