- 23 Aug 2007
Hi all i got given a 5.1 surround sound system i got it connected to my pc witch is using on board sound but is it worth getting a 5.1 sound card for this system?
Not looking to spend much but if i can get the surround sound for my games that would be nice.
here the spec of the system i have not sure if its any good or worth getting a 5.1 sound for it?
Toshiba dvd home cinema system SD-42HK
General:
Region 2 (PAL I/NTSC)
DVD Video
CD Audio
Bit rate display
Dimensions (mm): 360(w) x 82(h) x 350(d)
CD-RW
CD Video
MP3-Playback
CD-R
Digital Pll FM/AM Tuner
30 presets
Picture:
MPEG2 digital compression
27MHz 10bit D/A converter
Variable zoom (x1.5, 2.5, 4)
Enhanced D/A Converter 96khz
Digital still
Fast forward/rewind (x2, x8, x30)
Repeat
Icon On-screen Display (OSD)
Connections:
Component Video output
RGB / S-video Connection output
Optical Audio Terminal
Co-axial Audio Terminal
Analogue 2-channel audio output
Composite Video Input and Output
Sound:
210w RMS output
Dolby Digital compatible
MPEG2 5.1 Surround
Digital Theatre System (DTS) compatible
Sampling rate: 24bit/96KHz
Jitter Reduction
Enhanced Audio Mode (EAM)
Passive Sub Woofer
6 speaker package
Digital Amplifier
Interactive Capabilities:
Multiple Language Tracks
Multiple subtitle tracks
Multiple Camera Angles
Parental Lock
Chapter index
Thanks.
General:
DVD Video
CD Audio
Bit rate display
CD-RW
CD Video
MP3-Playback
CD-R
30 presets
Picture:
Digital still
Repeat
Connections:
Sound:
210w RMS output
MPEG2 5.1 Surround
Jitter Reduction
Passive Sub Woofer
6 speaker package
Digital Amplifier
Parental Lock
Chapter index
Thanks.
