Worth going for Atmos?
23 Nov 2004
UK
I'm thinking about a little upgrade and maybe going down the atmos route. Currently I have a 7.1 Denon Receiver, KEF Q500 fronts, KEF Q200 centre , KEF Eggs as rears and a KEF Q400B Sub.
Budget wise I'm allowing £500 for the receiver [2nd hand probably] but have no idea regarding the atmos speaker requirements. Do I need 4 or is 2 sufficient?
Cheers
I’ve got 4 in ceiling speakers that I use for Atmos and I think is amazing. Really pleased with it. 2 is probably fine, guess it really depends on the layout of the room, listening volumes all that kind of thing.
You could buy more kef eggs or size up to kef q8s.
To get a avr with all four atmos plus 7 amps for base channels you'll probably have to step to Denon 4700 check how many amp channels that has not just the processing
I'm using a 9.2.4 system
Which Denon have you got currently? It would seem a shame to step down a couple of product levels just to get atmos. You’d potentially sacrifice the quality of the amplifier for the front soundstage.
It's the BT540 so needs upgrading regardless
I replaced a 5.2.1 Atmos system paired with a Denon 4700 with Sony's HT-A9 wireless speakers/subwoofer with Atmos, and am really happy with the results.
It helps that my main TV for movies is a Sony A90J which works with that system as a centre channel.
I've also got a lot more space now I don't have tower speakers and a massive cylindrical subwoofer.
Don't you miss the pressuratuon he room with the svs cylinder?
I have 2 subs a 8" B&W and a 12" Kef. Bass I have covered. Looked at a couple of atmos receivers today from Denon and Onkyo. The Onkyo looked nice but I'm used to the Denon layout so a hard choice.
It may work but it might not be ideal or optimised correctly.
If you get a new AVR make sure it had two subwoofer outputs, and seperate ones.
Why? Most AVRs don't do much in regards to time aligning subs and essentially still treat the two separate subs as one when it comes to measuring.
Most people are fine with one subwoofer output from their AVR and if they do fancy going for multiple subwoofers, should buy a MiniDSP2x4HD or better. This will allow to increase sub count to 4. You can then time align and calibrate the subs together via RoomEQ and the MiniDSP app. Once dialled in to the best of your ability, connect to the single output subwoofer and its all good. To limit distortion, try to manage levels of the sub outputs manually rather than adjusting gain on the MiniDSP (being a bit of a perfectionist).
I know a few AVRS do deal with both subs as individujal speakers but they're rare and expensive - and still won't give better results than a miniDSP (DIRACT live new bass management and Trinnov's new stuff might prove this wrong but doubtful to come to mid-range and introductory AVRS for a few years).
