I am in the same boat. But I have a 4870 512MB.
Excuse my ignorance, but am I right in assuming the 4870X2 is better than the 5870? If so then why wouldnt one go for the 4870X2? Or have I got the wrong end of the stick here?
Thanks!
The 4870x2 uses more power on load and idle, requires CF profiles for games to get any benefit, and doesn't have DX11.
the 58xx series have none of those problems, the 5850 appears to be damned near as quick as a 4870x2 and the 5870 is pretty much on even pegging with it.
On a single GPU that requires no CF rubbish, uses 25w when idle [don't even ask what the 4870x2 uses, it'd scare you] and has DX11 hardware support out of the box, and can trade punches with the very fastest GPUs in the world, and that's before you look at crossfiring the 58xx series cards...
Hope that helps.
Perfect. Thanks for the explanation. Much clearer in my mind.
Question now is can I afford to part with 300 (less 60 for my 4870 or so).
is it worth going from a 4870 1g to 58701g i dont game a great deal but do game at 1920 x 1200 i only put aa on in the game settings unless if not leave it off or wait till later will ther big a big diff
I doubt it very much it would be a bottleneck, Espcially if its oc'd ~3.2ghz.Yeh i'd really like to know how big the difference is in terms of performance aswell and will my current q9550 bottleneck the card at all?
