- 12 Dec 2002
Im planning on staying with my current Q9650 @3.8ghz and P5Q-E for a couple more years and am concidering buying another 4GB of ram seeing as its rather cheap, will there be much benifit in gaming?
Erm, as long as you are using DDR3 then I would say yes depending on what you use for system for.
If you are gaming at 1920*1080, video editing or using heavy resource software then yes the extra memory will help! Especially in games such as BF3, MW3 or DiRT3. xD
DDR2 isn't particularly cheap.
4GB will set you back ~£40-£50 at OcUK. It's double the price of DDR3.
As far as I'm aware there aren't many games which will use more than 4GB (waits to be shot down) but who knows where we'll be in 2 years time.
It's up to you if you think spending £40-£50 offers you some future proofing.
As a final thought I'll give you two things to consider:
1) You need a 64 bit operating system to make use of more than 4GB
2) Filling all 4 RAM slots may affect your CPU overclock
