- 2 Feb 2010
- Crowmarsh
I'm currently running a 1440p ultrawide on a 3070 and feel it still does pretty well. Is it worth upgrading to a 5070? Or wait another gen?
This.5070ti minimum, you want to at least double your VRAM.
Answer, no. Get RX 9070XT from AMD. Nvidia is taking the mickey. When the only 16 gig VRAM card costs up to £750.00 - £900.00-looking at you RTX 5070TiI'm currently running a 1440p ultrawide on a 3070 and feel it still does pretty well. Is it worth upgrading to a 5070? Or wait another gen?
It's not going to work very well with that 9070XT you're considering either lolIndiana Jones doesn't even work with RT on my card.
The 9070XT will work much better since it is supposed to be matching a 4070Ti in RT workload.
That's what people used to say about the 7900XT and 7900XTX as well, when they were convincing themselves that AMD could match Nvidia in RT. They were wrong then:
And there is a strong chance you are wrong now, but we won't know until March as that is the supposed release time of AMDs 9070XT.
Indiana Jones as you said, also has that full path tracing option. There is no way of considering AMD if you want to turn on high RT or path tracing. I wish it were different, I really wish they were putting something out which could compete. We would all be better off for it as it would give us more choice and drive down prices. But as it stands and how it's likely to still stand in March. If you want RT/PT and you want decent frame rates, Nvidia's cards is all we have.
What game are you showing and what resolution?
How does 4070ti handle it with dlss at 1440p ?
That's Black Myth Wukong at 4K but using FSR 3 upscaling set to quality. It's from the Digital Foundry 5090 review
Leaks are showing a massive leap for the 9070xt over the 7900xtx specifically in BMW raytracing.That's Black Myth Wukong at 4K but using FSR 3 upscaling set to quality. It's from the Digital Foundry 5090 review
It's worth noting that India Jones full path tracing is a heavier work load than this, so AMD would be even worse against the RTX cards
