7850 is a bit better, but not worth it to upgrade IMO
You can just buy a factory overclocked card if your timid about doing it yourself, you can get close to stock 7970 performance ones and maybe even some that match/exceed? /shrug.
). Reviews on the web and benchmarks regarding the SLI are very very positive.AHHHHHHHHHHHHHHHH!!!!!!!
So hard to make decisions!!!
I've been looking at alternative options over getting the 7950/70 untill the 8 series & Haswell (maybe wait longer) has come out and instead, get another 660 for SLI (I've only had it 4 months). Reviews on the web and benchmarks regarding the SLI are very very positive.
Would it really be that bad of an investment!! All the games I play would benifit and I've got the PSU to power them.
Cant you just hang on to the 660 untill the new cards come out?
Sure get another card, it wont be so bad if you can afford it. But then your be in a position to need to sell off two cards rather than one and make double the loss on the cards.
I dont think SLI should be seen as a short term solution.
I bet two 660 will be pretty decent, and maybe you can skip the new cards altogether?
7950 is the rather obvious choice.![]()
I'd rather get the 7950 than SLI 660 seeing as how its only got a 192 memory bus.
Just showing the performance of 660 SLI against a 680 and 7970. Give that some consideration before you make the jump, especially as you already own a 660 and have a PSU capable of powering 2.
Yes 660 are not too bad in sli they are equal to 660ti sli![]()
Where did you find that?
I'd be interested to see what the graph would be like with CryEngine3 & Frost Bite2.
This is what I meant earlier about SLI, the benchmarks looked really promising despite a 192bit bandwidth.
And PSU, I've for a 1000w modular with 4 PCI-e rails.
