Worth it?
16 Apr 2012
Dundee
Hello,
Would £1000 enable me to purchase a computer better than the following? I would require only the rig, no OS, monitors or peripherals.
Old computer specifications (bought in 2012, unable to supply links unfortunately);
i7 3770k
2x Gigabyte GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card
Intel 520 Series 240GB 2.5" SATA 6Gb/s Solid State Hard Drive
Asus P8Z77-V DELUXE Intel Z77 (Socket 1155) DDR3 Motherboard
Microsoft Windows 7 Ultimate - Retail (GLC-00181)
NZXT Switch 810 Ultra Tower Case - Black
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD
XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply
Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US)
Phanteks PH-TC14PE CPU Cooler - Blue
Samsung SH-B123L/RSBP 12x BluRay ROM / DVDRW DL & RAM Lightscribe SATA-II Optical Drive - Black (Retail)
Thank you in advance.
We are not allowed to give price check outside the MM.
I suggest you reword the question and see how close to that you can get for your budget - £1000 is it?
Will you need an OS again? Keyboard and mouse too? I assume you still have the monitors?
New graphics card/s would be the only parts id consider replacing. 2gb is cutting it a bit close with newer games. The rest looks grand.
i would sell the 680's and buy two 970's. after selling your 680's it shouldnt cost you that much to sli two 970 maybe around £300
Why 2 x 970's?
If he's running 1080p / 1440p one will be fine.
Personally, I have 2 x 680's under water and will be keeping them until they're struggling, which they aren't currently.
Sorry for the bump.
I was just curious if I'd to change anything to my build to support SLI 970's?
If not, could you recommend which 970 would be the best option?
Thanks in advance.
If i was buying a 970 now, id be going for the ocuk titan cooler version, best option for future upgrade to sli. 2x non reference cards in sli arent great tbh, but with the ocuk one, put it in the top slot and later add any other 970 for sli without temp concerns.
