Worth overclocking the Northbride
LMAO WAIT WAIT!!! IVE MADEA TERRIBLE MISTAKE I DONT MEAN FSB -_- I mean Northbridge!!! sorry lmao
Im very bored -_- and decided to have a tinker with my pc
Ive overclocked my CPU in the past but never really looked at the FSB or the ram. Ive noticed tho that ram overclocking on yeilds very small increase in performance. From what i understand the FSB helps buss the information around your pc (cpu to ram etc) So sounds perfect
Its currently at stock. I cant seem to find any pros and cons tho. The only website i found said it can cause errors in the hard drive and gpu ><
1: will i see that much of an increase in performance?
2: Does it cause errors in HDD's and Gpus?
Sorry to ask (it may sound like im asking for a lesson in how to overclock -_- I'm honetsly not. I just cant find the answer to the questions :'( thanks for your help!
Its currently at stock. I cant seem to find any pros and cons tho. The only website i found said it can cause errors in the hard drive and gpu >< 1: will i see that much of an increase in performance?
I do know a little from reading about. I think the fsb or cpu .. (bad with names ><) is currently set to default (300- could be 200 >< lol! Its a long time since ive looked at bios sorry) and the multiplayer is set to 19x which gives me 3.8ghz (voltage set at 1.475 (stocks 1.4 i think)
