Worth returning?
10 Sep 2006
UK
My P180 Mini came today, and upon insception there's a very small scratch at the top/back of the case near the 200mm fan hole, is it worth making a fuss about?
It really depends how much it's going to do your head in over the time you own the case for... If you're going to be forever looking at that scratch and quietly snarling to yourself then return it... However, if you're not overly bothered and will probably not notice it once you're set up and running, don't bother
Personally I would return it, little things like that would drive me nuts after a while
It's hard to say really without seeing how big the scratch is and if it's visible at all times etc
But new should be new, if you dont mind hassle then return it.
