Worth ripping it apart?
20 Oct 2002
North West
Currently I have a Lian-Li V1000B+ and a Arctic Freezer 7 Pro. Now my idle temps are 42/44 depending on room temp. Now under load in orthos and whilst watching a film at the same time the temp goes up to about 59 per core. Is it worth ripping my kit out and fitting a titan? I'm just thinking of those hot summer months ahead :(
Everything seems fine and while playing a game it doesn't get that hot (about 46/7 - 50), but these temps are obviously going to go up in summer.
what cpu do u have?
i just got a arctic freezer today and its beautyfull. im running at 1.68v on my amd 4400x2 at 2.8ghz and its still below 60c
wow well im supprised at your temp's then,
is the air flow good in your case?
i have a amd 4400x2 @ 2.8ghz 1.68v and it stops below 25c idle and 60c full load
Odd, I'd expect you to either get higher idle temps, or lower load. Airflow's ok. I also have an 8800GTX which adds around 4-6c onto normal temps.
