So I built a new PC a while back, and decided to build my girlfriend a computer out of old parts from my previous one. Almost immediately after installing Windows on it, the trusty old Enermax 650 died, seemingly taking out the motherboard with it.
After a lot of messing around, I've given up on that system. But I scavenged around my box of even older parts and tried to put something together for her anyway. The problem now is that I'm not really sure what bits are dead. I don't really want to spend money on a new PSU if turns out the memory doesnt work, and then the graphics card doesn't work, etc etc.
The mobo is a Asus P5k-C. The main problem is that the PSU seems to either be dead, or too weak. It's only a 430W, but its supposedly enough to power the system (which includes a 4780 gfx card).
When the graphics card isn't plugged into the PSU, the fans turn on but I get a long+3shorts beep code, which seems to indicate a video card issue. So, I plug the power into the card, but now the fans won't even start up. The CPU fan twitches ever so slightly, but that's it.
When I deseat the memory, I get the expected 1long+2short beeps, no obvious problems here.
So my question is, is the "twitching heatsink fan" a symptom of a dead PSU, or simply one that can't put out enough juice to power up the system? If so should I just grab a new PSU (500W?) and take the risk? Or am I likely to need a new graphics card as well?
Thanks a lot guys. This one's been bothering me for a while now!
