Worth Upgrading Client?
14 May 2006
Hello,
Been crunching for a while and to be honest it's just left running without a lot of attention paid to it. Checked the version on the console client and it's 1.90, is it going to make a major difference in performance upgrading to the latest version (looking at the web site 5.04)?
Cheers! :)
I haven't a clue, doubt it will do any harm, are you running a single core or dual core PC.
You'll need to stop the current client when it finishes it's next WU if you don't want to lose it. Depending on how you have set it up depends on where to put the -oneunit command to make it finish at the correct time.
