Worth upgrading ? HTPC 2 years old !
18 Oct 2002
At home
Hi,
Just looking back at my old emails and noticed that my HTPC is now two years old ! I use this PC everyday, for watching movies / bluray / surfing the net. Don't play any games though....
Spec is:
Gigabyte GA-MA69GM-S2H AMD 690G Socket AM2
OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM
AMD Athlon 64 X2 4000+ (2.1GHz) Socket AM2 Energy Efficient L2 1MB
Radeon HD 4550 512MB
Anything particularly bad with that spec ?
And just thinking out loud, if I were to play games on it ( as I just remembered I have a wired 360 controller I can use ) what would I need to upgrade ? I do have a 360 and Wii so not as important.
Thanks,
if you wanted to do some light gaming on it i would suggest changing the 4550 for a 4670, apart from that its a nice spec for a htpc.
If the computer works fine then I don't see the need to update any components.
Edit!!
The only thing in the computer that may need updating is if you have a PSU with under 80% efficiency as a more efficient one would mean lower electricity bills!!
Ok how about this guys ...
GFX - Getting the 5770 - About £120. Will play modern games, i'll get HD Audio. TV is only 720p so res should be fine ??
CPU - Some sort of Phenom quad core ? About £120 ?
Sound about right ?
Is my RAM really that bad, should I replace that ?
Ok think I wouldn't mind doing some gaming on my HTPC. Or at least give it a go :p
To play stuff like Dirt 2 at reasonable detail levels. 720p monitor so res is not huge.
Can I get away with just buying the 5750 for £100 ?
