Hi there,
I am wondering wether or not I would actually need to upgrade my PSU should I want to upgrade to an 8800 GTS/GTX in the near future.
My spec is as follow's :-
AMD x2 3800+ (OC'd to 2500mhz)
2GB DDR
ASUS SLI Premium
2 x 7900GT's
3 x SATA hdd's
1 x DVD RW
4 x 80mm Case fans
1x 120mm case fan
PSU - Antec Trueblue 2.0 480w (dual 12v with 18a's each)
If you would recomend upgrading, what would you go for between the OCZ's GameXstream 600w and 700w?
Cheers
2GB DDR
ASUS SLI Premium
2 x 7900GT's
3 x SATA hdd's
1 x DVD RW
4 x 80mm Case fans
1x 120mm case fan
Cheers
