worth upgrading to 4600+ from a 4200+?
16 Aug 2004
Hi,
right now I have an A64 x2 4200+ and was wondering whether the upgrade to a 4600+ would make any difference? Would it be better to get a 4400+ with 1MB cache?
thank you in advance
Yannis
Apparently not so you'd really notice. (cache size difference)
I'm well pleased with my 4200 and I'm going to hold out (save the extra pennies) for a 5000.
You could overclock to a 4600 easy, if your gonna make a switch I'd go with the 4400+, but I doubt either would be particularly noticable.
Stock for stock, not really.
Get the 4400 which has the same cache and with a small clock (should'nt even break a sweat) and you'll hit the 4600 speeds and have the same cache.
Performance wise i don't think you'll see much difference unless you OC the CPU some more, but even then you could OC with the current one.
If it were me, i'd say its a waste of money. I asked something very similar to this here....
