- 26 Dec 2013
- 404 Not Found
Hey. I am trying to figure out if I would benefit from changing my current cooler, Prolimatech Panther CPU Cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-012-PL&groupid=701&catid=2330&subcat=2349 for a Corsair Hydro H60 V2 http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-CS&groupid=701&catid=2330&subcat=2342.
I Was planning on mount it as a push/pull on the rear exhaust vent but pulling air into the system, then with 2 x 140mm fans on the top of my case exhausting air. I also have 2 x 120mm intake fans at the front of my case.
See my sig for system specs.
Cheers
Cheers
