Worth upgrading?
11 Feb 2009
Scotland
My spec is as you see below in my sig, is it worth me upgrading at all this month(i'll have roughly £200) or wait for a while until the i7s either come down in price or i have some spare money to splash out with..
I would ad RAM so total be 4GB if you are on 64bit OS
otherwise u do not need to upgrade as you have very good setup!
OC your Q2C if it's not .
Yeah RAM is only thing, imo whether youre on 32 bit or 64 bit Id upgrade to 4, you'll still notice a difference. Other than that save you money til you can afford a new system, just clock your CPU to 3 GHz, easy clock, theres not many things that'll get bottlenecked by it at that speed
