So, currently using the following couple of year old bundle bought from OCuK...
*OVERCLOCKED* AMD Phenom II X3 Tri Core 720 2.80GHz @ 3.30GHz / Gigabyte GA-MA790XT-UD4P Motherboard / Corsair Dominator 4GB DDR3 XMS3 PC2-1600C9D TwinX (2x2GB) Bundle
Although mine has 8gb of ram, and I think the overclock may have disappeared over time. For a couple of reasons I need to do a clean install, and will be upgrading to an SSD and Win7.
This then got me thinking, as the comps a little noisy with numerous case fans (case is a TJ09), should I invest in one of those Antec Kuhler/Corsair Hyrdo jobbies, and if I'm doing that, is it worth upgrading the CPU while I'm at it.
Unfortunately I have absolutely no idea if an upgrade on the CPU is worth it, nor what I could actually put in, I am way behind the times. I could go the whole hog and change the mobo as well, but then its getting to new comp time and not sure I can really be bothered to change everything.
Any recommendations?
		 ). This air cooler seems to be favoured as the best at the moment:
