Worth upgrading
18 Jan 2004
Sunny Scotland
Currently running a Dell UltraSharp 2707WFP have had this for a while and is a fantastic monitor but I really love the look of the Samsung S27A950D would this be a worthwhile upgrade with regards to picture quality?
I would be looking at going 3d at some point so would be future proof for that and I am really missing having a hdmi port on the 2707WFP.
Anyone else made the leap from a dell to the samsung
It will be nice going to a 120Hz monitor if you do a lot of gaming - since the 120Hz refresh rate will make fast motion feel smoother, the response time is lower (so less ghosting) and the input lag is a bit lower.
However, in terms of picture quality - your Dell will look nicer than the Samsung because your dell uses a rather nice S-PVA type LCD panel, while the Samsung uses a TN film type panel. S-PVA has the benefit of rather high static contrast ratio, good black level, pretty accurate colours and relatively wide viewing angles. While a TN panel doesn't have as good static contrast ratio, black level, colour accuracy or viewing angles. Also, the Dell uses a 1920x1200 resolution (16:10 aspect ratio) and the samsung is 1920x1080 (16:9 aspect ratio) - so the dell does have a bit more vertical resolution, so more screen real-estate, as well as slightly more viewable area due to the less wide aspect ratio and the same diagonal size.
As I say, the Samsung will be a better option for gaming and 120Hz 2D will look great (plus 3D gaming is possible) but don't expect the image quality to be any better than qhat you currently have.
If you would like superior image quality then I would have a look at a 27in 2560x1440 IPS panel monitor. These have superior image quality both due to a generally better panel technology and a higher pixel density.
Thanks very much for that information certainly makes the choice easier as much as the samsung is lovely I do allot of film and TV watching from the bed so it needs decent viewing angles but I also do play lots of games and 3d does appeal to me.
Will take a look for a panel you mentioned but will no doubt end up just needing to save more for the new Dell u2711 or the cheaper Hazro HZ27WD
Exactly - the U2711 or Hazro 27in - both of these use the 2560x1440 27in IPS panels - very nice monitors. As are the Samsung S27A850D and the HP ZR2740w.
Though out of all of these I would personally go with the U2711 since it is an overall really great monitor - and Dell's build quality and warranty service is excellent.
